blandy
Gaz Gha
blandy
I've got a set of gaz gha front coilovers and adjustable top mounts fitted on my 205 and I've got a issue with the adjuster part, if I was to fit the bonnet I'd have to raise it a little as the bonnet rests on the adjuster bit.
Has anyone else had similar issues as I even took the unit apart to see if it was built up incorrectly from factory but all seem ok it's just the length of the rod/adjuster
pip470
I also have this problem but not sure why. Watching with interest.
allanallen
I'm not sure what spacers/sleeves you're running with your top mounts but (as long as there's enough thread) I'd just fit another spacer under the rose joint.
blandy
There wouldn't be enough thread if I spaced it out as the thread only just comes through the nylock. I'll try get a pic I think the adjustable mounts don't help the situation as that's adding height.
blandy
This is the best pic I have
42500ED7-4616-4BA3-95B8-499B3B03B1E4_zps
allanallen
Those nuts are overkill IMO, a narrower one would be fine,some coilovers are supplied with them . The top spacer could also be made thinner to give more room, failing that some sleeved nuts so you can ditch the top spacer completely.
Lots of options buddy.
allanallen
Here's a couple of pics to show you what I mean. You normally used sleeved nuts to fit short spindle dampers into rose jointed top mounts. These are some I made to suit our 306 top mounts.
Smaller nuts and thinner spacers would be the easiest method mind, I'm sure you don't need much more room?
Edited by allanallen
blandy
Ah I see that's great thanks. I'll take another look tomorrow and see what suits best
