driversdomainuk
Starter Motor Issues
driversdomainuk
Hi All
Been having problems with starter motor at times, putting it in gear and giving it a push usually worked. However, I have just had a new starter fitted, and when trying to start, it fired fine. Tried again and would not start - could hear that "initialising" sound from under bonnet when switching the key but nothing else...
Garage were good and said they will try another starter for no cost...But apart from fitting a new start that happened to be a dud, is there anything else causing this intermittent issue?
Rob
Edited by driversdomainuk
Old corroded wiring and terminals usually.
jord294
what year car?
brown multiplug is common fault
did yo go for the slimmer/better 306 gti starter
AlexRS2782
Mine used to do this - it was only fixed after I gave the car to Miles and he redid all the wiring / connections on the loom that went via the brown multiplug and associated sensors.
Car has started first time every time since then :)
You should never say things like that, But as said Wiring, Ignition switch as each time you turn it it arc's and causes a high resistance joint, Big body starters are a waste of time even when new, they always bench test OK but never on the car
PhilNW
Try running a new wire from the ign switch to the terminal on the starter motor , worked for me
driversdomainuk
It looks like there is a tired wire from ignition switch to terminal - so thats going to be it...I hope
