JoeWright
Can Anyone Recommend Where I Can Get Black Water Hoses From Please.
JoeWright
Hi everyone. I want to replace all of my water hoses with new ones. Would like them to be black so it appears stock. Any idea where I can get them from, preferably half decent and not too much. I literally need all of them, including the metal ones. Anything that carry's water basically. Many thanks
Joe
Plumbob
Baker BM do black silicone ones? I've got a set (for a GTI-6 engine) but they do also do standard sets too.
Stew does rubber ones now too.
timoth123
I got a set of the rubber ones. Very good quality!!
JoeWright
Hi mate,
Are they new and does it include everything ie the plastic joins and bits. I need to replace them too and the metal pipes.
Joe
You can still buy most of them from Pug at not too bad a price, Should be no joins bar the chassis pipe which can be had from GSF for a few quid.
JoeWright
Thanks mate. My mechanic said I need all the hoses, including the metal tube behind the front driver's wheel (rhd) and some little plastic bit. Ill have to find out what he is going on about.
Joe
The plastic bit will be the water Dist union, bolts onto the block and the plastic ones are well known for falling apart with age, If you can find a used Alloy one or again these are still available from Peugeot
stew205
Hi Joe,
If you still need these have a look at our site: www.BakerBM.com
The full rubber hose kit is £135+vat and S/S inner wing pipe is £18+vat.
Don't forget to use your 10% forum discount!
