hudson
Best Cv Joints
hudson
What's everyone using cv joint wise I have quiafe shafts and have been using motorfactor joints but after the northwest stages I have found these to of cracked on the cages whilst inspecting them to put on the new car
Edited by hudson
Biggles
I've got Satchell shafts - 306/406 turbo diesel joints.
hudson
I take it the 406 306 cv joint is the same fitment spline wise then
The 306 joints fit the hub, but the spline to the shaft bar is a different size (slightly larger on the 306)
406 cv joints are larger again than 306, wont fit a 205 hub without some material taking off them inc the abs ring.
drive flange spline is the same but uses a 10mm tall spacer under the nut.
hudson
Thanks lads
