Andy_C
Servo Removal
Andy_C
Just checking I'm doing this right having spent an hour upside down in the footwell (no mean feat for a 6' 2" 17 stone lump!).
Taken off lower dash housing and I'm seeing 6 bolts with the circular spring washers. Got them off and 6 bolts - remove from the inside and servo out from the engine bay?
Really could do with being smaller and slimmer.
dcc
I am 99% sure the servo is just 4 nuts
and the clevis pin and clip.
Assuming you're trying to remove the servo and pedal box as a pair, there's more than 6 nuts you need to undo.
You're probably missing the partly obscured one in the top left hand corner, as from memory there's 7 or 8 nuts in total.
Undo all them, and withdraw the complete servo and pedal box assembly from the engine bay towards you, wiggling it out.
speno
I find using a quarter drive socket with a extension and a UJ is pretty good to get in there
Andy_C
Thanks chaps. Looking after 2 poorly kids so will attack this again at the weekend - appreciate the help!
woodymi16
These may be of help
Remove the steering coloum too, there's one at the top
Andy_C
All done - many thanks chaps
Twat of a job but I managed to get the last bolt (up behind the steering column) out with an 11mm socket on an extension bar.
