yeti-dj
Seam Sealer Recommendations
yeti-dj
Hello,
Just started to restore my 205 and looking for a good seam sealer to use once I have finished all the metal work, something close to what Peugeot would have used.
Any tips?
Here is progress so far
yeti-dj
Nobody??.
What have others used once you done a lot of metal work?
Andy_C
My paint guy has told me to use Tigerseal when I do my engine bay if that's any help.
yeti-dj
Was thinking about tiger seal
Probably gonna paint it in etch primer, then tiger seal, then mastic 121..
Hopefully keep the rust bugs away for a while
deathbringer929
alwya etch first then seal. i always use 3m spray sealer, its more fluid and easy to work that tiger seal or normal 3m. spray sealer sqeezed from a normal mastic gun and brushes out perfect too. a lot better than any specific brush on sealer.
you can buy shaped mastic tube ends aswell to recreats factory finish. door skin edge ones with the tab cut off work well.
Andy_C
Have you got a 3M product code? Think I might try that when I do mine.
yeti-dj
Hello,
So which 3m product are you recommending in perticular, have had a look on the 3m site but there are about 20 different sealers listed..
johniban
I've used a brush on seam sealer from halfords got good results but needs to be a good temp to use it or it cracks when it drys
