Tom_Gallington06
Scrap Yard And Barn Find Survivor....
Tom_Gallington06
Well i have just written up a whole 5 year overview of my progress and pressed back space which has lost my passed hour of typing!!!
So here it goes again.
So I bought a Red non sunroof 205 out of a scrap yard about 5 years again and took 18 months rebuilding it.
Spec
GTI-6 converison with gearbox
309 wishbones and D/S
309 Rear beam
GTI-6 Brakes
Stainless exhaust
It only took 4 months for some dimwit to write it off for me at some traffic lights because he though I was going to jump the red light??
So that car got stripped and I bought a Lazer of my mate. All my parts went onto this one.
My bad luck got even better when someone drove into the rear quarter when it was parked. Topped off with my parents dropping a big branch on it to dent the roof. So I was mega happy.
So next I moved on to another hunt for a shell. This time I struck gold with a barn find. £250, 40 miles away. Here it is.
So I set straight away to stripping it and cleaning it thoroughly.
Then just built it with all my parts from my last one and enjoyed it.
I then got some GAZ GHA coilies and fitted them
I aslo killed a head gasket after a couple of trackdays so the engine was swapped.
Next I bought some Jenvey 48’s and omex 600 which I loved the sound off, way to additive.
My mate was then selling some 45’s cheap so I had them and moved on my 48’s.
I was a GTI-6 head for sale on the forum which took my fancy to I bought that.
Spec:
Longman head
Piper 285 solids
Solid lifters
Double Valve springs
Vernier pulleys
So then I had to get a bottom end built. After some thinking I decided to build a beefier bottom end. Not just a fresh built standard bottom end.
Spec:
Re-linered block (86mm)
Lightened and balanced Crank
ACL race bearings
Omega pistons
Saenz rods
ARP bolts
Lightened flywheel and bottom pulley.
I nice delivery this was....
So this all got sent to the engine shop and was machined, inspected and rebuilt.
So I got to go collect this
I then built all the various parts up on this engine and got it fitted.
As well as a new set of coolant hoses, breather catch tank and a few other bits and bobs like a 309 front Anti roll bar and fitted a roll cage.
Then off to the dyno were it didn’t make great power 198bhp. I put it down to cam timing and the exhaust as it is only 1-7/8” to 2”
F5BEC59A-9733-45B8-84E9-8EAB6FD6F2CB_zps
I then took I to my mate where we done some cam adjustments and trumpet length adjustments. And smoothed of the power band and got a few more bhp out of it (207Bhp)
6CB38FC4-7660-486A-B8CB-E7202A1999E9_zps
So I have been enjoying it now and done a trackday which indicated I need a diff. So a 3J driveline will be added soon.
Also a full 4-2-1 exhaust manifold and with 2.5” full system will be added soon. So that should finish it off for now until I crave wild cam’s and more power. The bottom end should be fairly strong to see through a fair amount of power increase so aslong as I have enough room with the valves and pistons new cams and a map and that will be about it for this build.
calvinhorse
Very nice in all 3 incarnations! :) like the battery box air filter set up!
rallyeash
Smart! Inlet manifold looks very short though. If changing the exhaust which being 2' will make a difference I'd look at a longer inlet manifold while at it.
Tom_Gallington06
Many thanks. Still some tweets and final things to do but should be a good all round fast road track car in the end.
Tom_Gallington06
I was originally going to fit a satchell Inlet but no mappers in the East that I know of like them compared to the jenvey one. Because of the jenveys being upside down I think.
selfyyy
Unlucky with the first 2 mate, current one looks mad though :wub:
hudson
Looks a great car you've ended up with eventually lol at least you'll have plenty of spares
Tom_Gallington06
Thanks pal. Worth it in the end. Still craving another red non sunny though.
Tom_Gallington06
Yes I do. I have a shed full I need to clear out. With a 3 spare Gti-6 engines and all sorts of stuff.
Looking at getting another shell and doing a Gti-6 turbo build next. Full home built garage special :-)
how do you "re liner" a single piece cast steel block with no liners? :unsure:
Easy, well known thing to do and most capable machine shops can do this, It will get more common with the Iron block engine's as we know, I guess it's more of a classic car thing to do with the liners
Tom_Gallington06
Correct. So I didn't have bore it to an 86.5 or 87 as I had 86mm Pistons.
Phil205gti6
Good little thread, hope to see it expand soon with the new bits your planning to buy! Noticed a very handsome chap welding your cage in there too ;)
That engine speaks for itself when you passed me on track!
Dizzee stuff
The red 1.6 shell looked in good nick did you scrap it ? as it looked a fairly easy repair.
Tom_Gallington06
Cheers Phil. Well hopefully soon we will see tho.
Dizzee it was a really clean shell. I think I was just devastated and it had actually pushed the left ache out and kinked the rear quarter so not just the boot.
Tom_Gallington06
So I went out to start my 205 today as I am thinking about putting it back on the road and I haven't started it for a couple of weeks. I went out and the engine was turning over slowly, so I put the battery on to charge and watched a film. It sounded like the engine tried to start a few times but never started properly. Then after a while it just turned over and over and didn't fire again or even try to start.
By this point it was dark so I just locked everything up and have came in for the night.
What do you think would be the first thing to check in the morning? Its on an Omex 600 and bodies.
Cant wait to get it back on the road, it will be having the final couple of parts it needs soon.
j_turnell
Maybe it wasn't syncing up as it was turning over slowly. I'd take the plugs out and burn them off, crank it over with the injectors disconnected to get rid of any fuel in the cylinders and then try and fire it up.
Tom_Gallington06
Ok I will give it a try in the morning and hope it was just flooded. It was turning over plenty fast enough to fire and I got the odd back fire.
Cheers for the help :-)
Edited by Tom_Gallington06
Reebmit
Interesting thread Tom, such bad luck in the early days! Really liking your current car, getting it ready for the summer a good move ;)
Tom_Gallington06
Thanks pal. Yes well I took it of the road as I thought the weather was going to be the usual rubbish and it's actually been dry most days.
A couple of upgrades in the pipeline for the summer so should be a reasonably good fast road/track car. :-)
Now keeping my eyes open for a shell for my turbo lump to.
Reebmit
Ha always the way, I always have that dilemma and always get it wrong :)
Be good when you go the boosted route! Will you keep them both?
Tom_Gallington06
Yeah I can't wait but don't want to rush it. I have an engine ready. Just want to do a ground up build with it. And I will definitely be keeping both. :-)
Tom_Gallington06
After a few days I have managed to get the car started. I ended up reducing the fueling on the cold start cranking map. And for some reason it wouldn't run on my iridium plugs. So I have replaced the plugs with some NGK-R ones and it runs a dream.
So off for its MOT Wednesday and then exhaust time hopefully.
And then hopefully I can have a chat with 3J driveline at the Autosport show at the NEC on Thursday and convince them to do me an awesome show discount. :-)
Can't wait to get out and about in it when it's sunny.
Tom_Gallington06
So a bit of an update even though not a lot has happened.
I've bought myself a welder so I can do some tidying up and maybe make myself an exhaust as I fancy having a play.
Diff is on hold for now as I'm saving for a mortgage so the 205 is on a strict budget at the moment.
Manages to get it insured for £329 which I was very please with and it went through its MOT with some minor tweets.
Exhaust parts have been ordered so just waiting for delivery. This should hopefully unleash a few top end bhp.
I will post some pictures of the exhaust progress next week.
rallyeash
I've just made an exhaust, check out my type R thread
