rallyeash
309 Type R
dcc
Ash just pack up, sell everything, and walk away...
Pahahahaha
Talk about a chocolate teapot calling a kettle useless... Bahahaaaaaha
rallyeash
Hehe probably the last time stu posts on this thread!
Picked up another bush the same this morning as will use the same one for both engine and gearbox.
stu8v
Crack on, 1/4 plate or bigger will suffice. ;-)
May weigh you down somewhat!
rallyeash
I had those brackets spare, pre drilled and cut in that shape so were used :)
Shouldn't think with 225hp and 800kg I'll be too worried about an extra kilo
allanallen
Stu, seriously? I'm all for constructive criticism but the piss taking comments with little explanation is a bit unnecessary don't you think?
Ash isn't a welder/fabricator/car builder and he's having a go at doing an unconventional conversion, yes 1/4" plate is ott but it's to hand and bloody strong, nowt wrong with being 'belt and braces' about stuff like engine mounts, especially when weight isn't an issue.
rallyeash
Maybe it's just jealously! Either way I'm not really bothered.
Correct I'm not a fabricator, I have a good idea on things and love self teaching. The end result won't be as clean as if I took it to a specialist place for a conversation but for me there's more satisfaction in doing it myself and learning. I'll make mistakes along the way as we all do.
It'll work perfectly fine, reliable and most of all safe by the time I'm finished.
If it's not a work of art like for example Davenports 106 XSI (the rattle box) I'm really not fussed.
blandy
Nothing more satisfying than building it yourself
rallyeash
So I've been playing with the gearbox mount and head scratching on what to do, the bush above wasn't really strong enough and sagged which I wasn't keen on. So I decided to make something similar to the pug setup
Two studs stick up here, the rear one is a lower and the original mount is a step down design.
Couple of spacers I had bring it back up level.
I cut out a section of steel drilled holes to mount, drilled through the centre and added the original peugeot gearbox stud. I welded it on the underside, few tacs around the top and painted it
I then made a mount for the peugeot gearbox mount, I'm using a standard pug one but if it's not soft it's then dead easy to swap to a bm item
rallyeash
Before stu comments it'll get tidied up, rounded off and all that when the engine comes back out. Hehe
allanallen
Are you gonna brace the mount on the body up a bit ash? My only concern would be that bit bending.
rallyeash
Yup going to add side supports. But it's easier to do once the engines back out.
madspikes
Nice -It's frustrating when you go down a path to solve a problem such this, and spend hours working on it. Then after a think decide that all the previous work was bollards, and a far simpler solution was staring you in the face all the time.
Clive
rallyeash
It really is! But it's just part of carrying out a non documented conversion. Once I finished the gearbox mount I was thinking I bet it would now bolt straight into the original pug gearbox mount/battery tray. Which would of also meant I could keep the battery under the bonnet! Ah well. Live and learn. It'll be better in the boot anyhow.
Could you not use the other tapped hole that is near the rear one on the gearbox? Make up a bar spacer that picks up the rear one you have used and also the other tapped hole, then incorporate that into the plate you have made?
Also seems a shame you couldn't have made a chassis bracket that used the original captive nuts, just to allow you to unbolt and remove which could make things easier in the event of needing to do say a clutch change with the engine in the car.
All constructive criticism by the way, keep at it.
Dj_mini
Love the idea of this conversion ever since I had a go in Sandy's 309 with the h22.
Keep the progress up ash some times trial and error is the best way to get something that works well in the end!
rallyeash
I did look using all three and originally the plate did this, however it was very tight against the chassis and with a 6mm plate I figured it'll be perfectly strong enough on the 2 so chopped the plate down. I will be drilling through and bolting short M8 bolts through the plate to hold the gearbox mount as original. Again a job once the engines out. Probably tomorrow actually.
No worries, constructive is good, helps improve.
rallyeash
Dan, cheers, btw I found those arches a couple of days ago! Typical! Had fallen down the back of some racking.
rallyeash
Tom, possibly could of made a removable mount, the 205 one is welded in and it's still easy to remove the box dropping it out through the nearside arch so shouldn't be to much of a bother.
rallyeash
So got the engine mounts finished off and some good progress
309 GTI arms and Gaz coilovers handed down from the 205
Which come with eccentric top mounts
Back on 4 wheels (borrowed from the 205 while it's apart)
Engine back in permanently sump clearance is fine
Subtle - ish
rallyeash
All it needs to make it a proper sleeper is some nasty halfords wheeltrims :lol:
  • Like 3
artois7
Brilliant! Nice work mate.
rallyeash
They will be 309 outers and Honda inners. Most likely a glorified cut and shut but it's not something I'll entertain. When purchasing the engine I got civic shafts so I'll take 309 shafts and civic shafts to a company that can balance them.
Possibly Colin Satchell or Watson rally.
