gizzmo
Ptfe Inlet Manifold Gasket Mi Head
gizzmo
could some one point me in the direction of where they may be bought from
An ebay seller called stevencowie often has them listed but doesn't seem to have any right now, it might be worth messaging him.
gizzmo
thanks for the info been in contact and he going to supply me with them, many thanks
GilesW
Interested in this too gizzmo.
How much are they?
SweetBadger
I wouldn't go for a ptfe one - ptfe creeps under pressure so the gasket deforms over time.
That's what happened to the 4mm one I used to run.
I've just bought one from here: http://www.ferriday.co.uk/thermal-products/
Not made from ptfe and should not creep. Having my car mapped tomorrow so won't be able to report back on how it performs over time for a while yet though.
Edited by SweetBadger
I've had one of phill Moffats ptfe gaskets on my gti6 engine for 5 years without any problems.
I think its a bit thicker but how thick I cant remember.
GilesW
who is phill Moffat Me I, and does he still do them?
I just want to make it clear that I have no connection to the seller on ebay that I mentioned earlier in the thread, I see they have listed a gasket on ebay since this thread has been running but at twice the price they were selling them for!
gizzmo
yes he seems to have over inflated the price since contacting him, normally they sell for 25 going on his feed back,i wont be buying one at that price justed emailed him with my query see what happens
gizzmo
they look really good. got the same issue of for mapping,and can fell vacum from around the manifold, they seem to offer group buy discount, if theirs any one interested going to contact them tommorrow
wicked
Thermal Exhaust Plates (T.E.P.s) – to reduce heat-soak from the exhaust manifold back into the cylinder head casting.
TEP-300x93.jpgAn exhaust manifold (especially turbo) is a large store of heat that should not be allowed to find it’s way back into the head – limiting this heat transfer can only be a good thing. Our Ferratherm material limits heat transfer to such a degree that an open Propane flame (approx 1300 deg C in air??) will only make the very surface of 4mm thick material glow red – no more than a fraction of the thickness can be made red hot – the rest of the material simply stays its own natural colour.
Is this really an improvement? If your turbo manifold is not cooled via the head, it will get hotter and crack sooner??
GilesW
I'd be interested.
gizzmo
I'd be interested.
contacted the chap thursday as yet he dosent do the mi16 one but has said if i send him a gasket their would be no problem making them unfortunatly mapping friday i dont have enough time to send him one over but will do their around 45 pounds if your still interested after mapping will get a gasket over unless some kind person on here has an old one i can borrow for copying?
SweetBadger
Get him to do a XU10J4RS Gti-6 one - it's the same as the MI, just one gasket instead of two, and I think the holes for the locating dowels are slightly off but it fits fine.
I have the same one on my MI16 at the mo; ordered it and he had it with me within a couple of days.
gti6 doesn't have dowels, it used two studs to locate the manifold instead of using bolts all round.
