gtiburge
Very Odd Running Problems
gtiburge
http://forum.205gtidrivers.com/index.php?showtopic=60923
i have the exact same problem that is described hear i have emailed the person who started the topic and as of yet no reply wondering if any one else can shed any light on the mater
things i have done allready
new recon afm by atp electronics
new plugs leads dizzy cap and rota arm
new ecu temp sensor
used new to be good ignition amplifier reapplied paste
new plug for ignition amplifier as wires where not great
new sad
cant find any air leaks replaced inlet mani gasket
completely baffled
Bobbafett
Have you cleaned the throttle body bypass screw? Makes the idle rough when it's dirty.
One day I drive my 205 and it pulls like a beast and the next it runs like crap. I'm convinced these cars have an actual thinking consciousness that likes to torture you sometimes just for the hell of it. Only thing you didn't mention was the ignition coil. I did have a problem with big power drops recently which turned out to be the coil.
gtiburge
have you got the coil on the right hand side of the wing as that is what i have ?
Bobbafett
Nah i've got a motronic where the coil is mounted on top of the inlet manifold.
Weser
coils were mounted on the passenger wing on phase 1 cars
gtiburge
yh i have a phase 1.5 1988 switch over year coild on pass side wing
scbond
Have to tried running a full setup of the idling components? Mine had issues which the past two owners couldn't solve and was probably why the first one sold it. I gave it a good clean and setup, including the SAD and the AFM (which had to be replaced) and it fixed the issue. Looks like you've done everything else.
