DamirGTI
306 1.8 8V Gearbox Ratios ?!
DamirGTI
As above , anyone knows which gear ratios has an gearbox from 306 1.8l 8v ?
Thanks !
D
calvinhorse
Sorry to crash your party but I'd be interested to know the ratios for the 306s-
1.8 16v xs
2.0 8v xsi
dcc
the 1.8 8v is showing 4 boxes on service box, but not sure if they would have all been used, as there seems to be only 2 cw&p's available. I am sure Meirion will be along shortly to clear that up!
But I was under the impression that all 5 speed 16v gearboxes in the 306 were 4.42 final drives :)
calvinhorse
Shhh the cwp is top secret :D
Cheers Dan!
dcc
ha, with that you should be able to find the ratios easy enough on service box ;)
I know from past experience the 2.0 XSI 8v has quite a short box. Makes for a low top speed as the gutless engine only revs to about 6000rpm!
calvinhorse
So would be ok in a gti6 205?
I've got a really clean really low miles one
find the code off the box and you'll be sble to narrow it down a bit
DamirGTI
1.8 8v box is :
1- 3.45
2- 1.85
3- 1.28
4- 0.97
5- 0.76
FD- 3.94
D
dcc
what code on the box for that? as there are 4...
DamirGTI
No idea Dan :blush: .. it's just something i got from forum member via pm :
202650625a737c20b37876c0e24c8d22315de506
How come theres 4 different ratios for 1.8 8v box ?! .. seems to me a bit unusual , why would they make 4 different ones for the same car with said engine type ? (certainly doesn't sound cheap solution manufacturing wise ..)
D
Are you sure about that? The 'box off a 306 1.8 16v I had was a 3.94 FD and I've nothing to suggest it wasn't the original gearbox.
wicked
Doesn't have to be intended to use 4 flavours. Could be that the ran out of stock of a gear set and took that was in stock... (belt stop -> big $$ loss )
Or that it turned out to be cheaper to use another set.
Sometimes ratios are also related to the fitted tire size / trim / model. (larger rims / break vs hatchback)
S@m
A friend of mine has a 306 1.8 16v cabriolet gearbox in his 205 gti6 and that too has a 3.94 final drive.
dcc
I feel I might have missed an important segment of info from this, there was a date which they were all 4.42! I'll try and find out as I have it all written down somewhere
