pugspence74
Lights On Warning Buzzer Relay
pugspence74
Hi does anyone know the location for the "lights on warning buzzer relay on 1990 1.6 GTI?
It's under the dash on the drivers side - white relay looking item about an inch cubed, to the left of the steering column.
That said, it's only present on Phase 2 cars from memory, which wouldn't be until late 1990.
pugspence74
Cheers Anthony - yeah Phase 2 - although think they put a few bits from phase 1 in her as well as some parts are really difficult to get right? HT leads being 1 of them.
pugspence74
Have just changed the alternator which has sorted a few problems but still have no side lights or lights on warning alarm, I have also changed the the lights on warning relay but still nothing? really confused? anyone had problems with Sidelights not working?
Weser
Have you got power to the bulb when they are turned on? I am afraid its a case of getting the multimeter out and checking through it all bit by bit. I.e have you got power at the bulb when they are turned on. If yes then you have got problems with the earthing side or the bulbs, if no then there is problems with the supply side.
Work your way through it all. It could just be a poor connection or a dodgey earth. Clean it all up and test it out. Your get there. Have you checked the fuse?
pugspence74
yeah all fuses are fine, its just the fact that warning buzzer and sidelights both stopped at the same time? so did not know if they are connected on the same relay or something?
no relay on the sideligts.
Weser
Im sure they will be connected somehow because the warning buzzer will probably work on the side lights as they are the first light to come on with the switch and they stay on.
Edited by Weser
