idoari
Ecu Temp Sensor - Where It Connects?
idoari
Hi,
i doing a full engine rewiring and i noticed that the ECU temp sensor has a spade connector on one end of it.
i almost sure that it was connected to one of the spade terminal in the 7 pins brown connector in the engine loom but i'm not sure which.
the seven pins turn to be this :
pin 7: water temp gauge sender
pin 6: water temp warning light
pin 5 : starter
pin 4 : oil pressure warning light
pin 3 : oil temp gauge sender
pin 2 : oil pressure gauge sender
pin 1 : alternator
in the haynes manual the ECU temp sensor , SAD sensor ,ignition amp and pins 5 and 13 needs to be connected together to the battery (-) terminal.
image.jpg​
but what i have it like this :
image.jpg​
*can someone confirm where the other side of the ECU temp sensor connects to?
*is the other side of the SAD supposted to connect to ECU 4 and the starter?
*where the SAD and the ECU temp connects together to battery (-) terminal?
thanks
Ido
idoari
can some one confirm that one of the pins one the ECU temp connector and thr SAD sensor is ground?
Ryan
Yes, one pin is ground and the other goes to the pin on the ECU.
