erbs
Aerosol Spray Dye
erbs
Looking for a dark grey dye in aerosol form but only found on the bay for £7.99 and £8.00 postage which I think is :lol:
Anywhere that is more of a reasonable price?
dobboy
Fabricspray.co.uk
If your doing carpet and console i'd get two tins, it doesnt go far.
mrfirepro
Hi Jamie,
Can you let me know how you get on as I have the same job to do in a few weeks time..
what colour did you use, did you do headlining & sunroof cover?
Edited by mrfirepro
acox99
I used a cheapo £5 tin off eBay.
http://pages.ebay.com/link/?nav=item.view&alt=web&id=270889882315
My shelf was white on the rear edge. Worked a treat. No crispyness what ever.
I can take a picture on Monday if you would like. I should have done a before and after but I didn't think it would be as sucessful as it was.
erbs
My pug is a non sunroof so headlining all ok
Edited by erbs
Dizzee stuff
that link is for 12 tins at £50
acox99
I couldn't find it individually in the short time I had to look. But that was the exact product I used.
dobboy
supposedly normal spray paint works on parcel shelves.... I wouldn't want to be the first to try it right enough
The "simply spray" stuff works good, but you don't get much in a tin, so if ever doing a carpet do it in a garage (vertical if possible) so as not to loose too much paint to the wind. (Make sure the carpet is power washed first too if doing a carpet.)
acox99
It does work but it makes it feel crispy a git like an old bath towel that's been washed and hasn't been through the rumple drier. It can look patchy too. Typical car dealer trick to fake a car up if it's a bit dirty inside.
