MikeM
Rear Beam - Reputable Companies
MikeM
Hi Chaps,
Had an early start in the garage this morning to remove my rear beam as it has play in the drivers trailing arm. I have rebuilt beams in the past but I just don't have the time to do it any more. I have partially stripped the beam to inspect, just letting the the torsion bars soak in release oil before I attempt to remove. Going on the condition of the seals, I would suspect that the shafts are more than likely to be useless, I have all the new bearings/seals to rebuild from a previous bulk purchase but I would suspect I will need new shafts.
So to cut a long story short - Are there any reputable companies who recondition axles? I have seen one or two folk who offer this service on the forum and also a couple on Google, but would like to gather some opinions before going any further
Mike
Juttie205
I recommend jord294 off this forum
johnhenry
+1 for Jord -
Top notch build, super friendly, SO happy with mine!
Not sure if he is still doing them or not, but honestly get in touch with him
