Ams
Xasara Vts Phase.2 High Pressure Hose Leak
Ams
Hello, I've just had my VTS Phase.2 PAS system fitted, unfortunately a leak has been found in the rubber section of the high pressure line. I've noticed the part is NFP on servicebox (besides, it's around £200!)
I've been informed that a Hydraulic Hose specialist should be able to fix the leaky section by replacing it with a hydraulic hose and soldering new fittings on the solid pipe section. I've tried one place and they wanted to know details that I could not answer such as :
Operating Pressure on line.
Operating temp of fluid.
Material type.
Type of joins.
:wacko:
Is there any further advice anyone can provide as to how and fix this issue? I could say its a hydro line for a dumper but may get the above questions flung at me. Honestly I'm just hoping someone has a high pressure line to sell! :blush:
Elp!
Try another hydraulic specialist, I've had PAS hoses made by several different places and they've never asked me anything else once I said it was for power steering.
dcc
iirc, you can get this hose from berlingo's
Ams
I'll definitely be trying another place Jack, I'll take the high pressure pipe section to this next place rather than speak over the phone :) Dobboy recommended a place nearby so I'll see if they can help. Dcc is there a specific model of Berlingo I should be looking at? Also what model year would it be?
Thanks for the suggestions.
Ams
I managed to obtain a replacement VTS P2 high pressure hose. I hope this one is functional. :mellow:
Edited by Ams
