Gavin Waddell
Unknown Plugs In Loom
Gavin Waddell
I am reinstalling a loom in my car, as the old one had been chopped up a bit to much. I have pretty much got everything plug backed in but have five plugs that i dont know where they go. Any one got an idea?
the first four come out near the fuse box
the last one comes out in the centre console ( i know that its not the clock, or thr cigarette lighter
thanks gavin
blue pair is the glovebox lighting, red is part of the stereo wiring iirc.
look for the wire numbers.
Slo
1st pic glovebox light switch
2nd pic no idea
3rd pic is a spare i think could be radio as wp says above
4th pic glovebox light
5th pic heater blower wiring dash control
MikeC
What are the wire numbers on number two?
I have a soft copy of the wiring diagrams from the workshop manual here on my computer
MikeC
Is the second the instrument rheostat? Numbers :ph34r:
No, that's a four pin brown plug (with only two wires)
MikeC
Can't make out the numbers from the pic :blush:
Gavin Waddell
The beige cable is 14 j
And the other m106
Stu
i think that red plug (pic 3) is the rear speaker connector that goes to a sub-loom to the rear.
Slo
Wire 14 is the dashboard illumination circuit the J is just a location id, connect a bulb to the wires and see if it dims with the lights on while turning the dash lights dimmer
Gavin Waddell
Thanks everybody, pretty much got it worked out.
Gavin
MikeC
14j and m106 is showing as being connected into the fuseboard.
PM me your e-mail and i will e-mail you the drawings if ya like.
Gavin Waddell
Hey mike
Thanks for your help, you say it plugs into the fuse board, only thing is my fuse board is already full? The loom I'm installing is not the original one I bought it off a forum member. Is there maybe a difference between ph1.5 and ph 2 looms, as I have an extra plug which I reckon is for electric windows.
Gavin
MikeC
Perhaps gavin.
I have mailed the drawing to you. The type of fuse board you have will be dependant on the chassis number.
I might be able to dig out the phase two drawings but it will take a few days.
Mike
Gavin Waddell
If you could find the phase 2 that would be great that way I can cross reference the 2.
Thanks again mike
