wicked
C2R2 Max Brake Discs
From the images it looks like there is no offset on the bell to the disc, and looking at the drawing above it looks like there is none there either, though theres no total height listed, if its around the 33mm mark youll be able to make them fit.
wouldn't be my first choice of disc though, they are rather expensive! Try godspeed brakes.
They are used on a 307 hub with an 807 radial brembo caliper and a bracket.
wicked
I've already a set of Megane RS brembo's with adapter made to suite the 307cc discs. The 807 calipers make use of wider discs (30 or 32mm?).
They are expensive, but the 2-piece discs listed for 106 at godspeed are also in the 400 quid ballpark? C2R2 are ~500 euros.
C2r2 setup used alloy inserts in the pistons to make up the difference.
RossD
Diagram shows 7mm difference between disc face and mounting face.
You missquoted me there, look at the c2r2 bell.
RossD
Yea, quotation selection was a little random on my part. There isn't a total height listed, however you can calculate it to 33.1mm using the dimensions shown on the tech drawing above.
