amusingadam
Fuel Pump Relay
amusingadam
Can someone tell me which relay is for the fuel pump as I went to start my car and just turns over no fuel in the return pipe and no power to the pump then all if a sudden it fired up so I'm guessing at the relay unless there's anything else ?? 1987 1.9 ph1 thanks
its likely to be the long black one by your ecu, just above your right knee.
amusingadam
So there's nothing but a ecu under the center console but under the bonnet there's 2 relays in a plastic box big one is bosch 0280230006 7 pins quick google says fuel injection relay just checking this is what I'm looking for
that'll be it then, must be an early 87 car.
amusingadam
I searched for something like that and couldn't find it. Cleaned all the terminals up from brown status everytime at the moment but will get a replacement just incase much appreciated thanks
Edited by amusingadam
