Tom Fenton 1,548 Posted September 17, 2014 I love tools, I'm sure some of you guys do as well. So this thread is for those things you couldn't do without. First off cordless impact gun, best thing I have, this has saved me literally hours in the past http://www.dewalt.com/tools/cordless-impact-driverswrenches-high-torque-wrenches-dw059k-2.aspx Next up is a recent one for me, my brake pipe straightener. If like me you are picky about wiggly brake pipes this is for you. Simple but so effective. http://www.kwixuk.com/product.html One many will have seen, Irwin nut grips, worth their weight in gold! http://www.irwin.com/tools/screw-bolt-extractors/5-pc-bolt-grip-expansion-set Finally one I bought the other day, spring pin punches. If you are stripping a BE gearbox these come in very handy, you will struggle with out them to be honest. http://www.buckandhickman.com/find/keyword-is-roebuck/product-is-216225 So what are your recommendations? Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted September 17, 2014 (edited) That f***ing pipe straightener! You're a perv! Oh and not forgetting your fancy pants cable tie flush snipper things!!! I haven't got any fancy tools Edited September 17, 2014 by allanallen Share this post Link to post Share on other sites
stufarri 98 3 Cars Posted September 17, 2014 (edited) That brake pipe straightener looks awesome. I need to do mine on my Goodwood so I'll be getting one, they are local to me too. I'll get another bigger one to do the fuel pipes too. Edited September 17, 2014 by stufarri Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted September 17, 2014 That f***ing pipe straightener! You're a perv! Oh and not forgetting your fancy pants cable tie flush snipper things!!! Ah good point yes, I had forgotten about those and I would not be without them. Those come from when I used to work for a guy doing rally car prep, he was very picky about certain things, one of which was chopping the loose end off cable ties. If you do it with normal pliers or cutters it leaves a razor sharp "tang" sticking out which is usually conveniently placed to rag the back of your hands to ribbons just as you are reaching for that widget nearby, because the normal cutting jaws are ground with a bevel on both sides. Flush cutting nippers have the jaw ground totally flush on one side, so you can chop the tie off flush with the "latch" part. Expensive and MUST NOT be used to cut anything hard as it will mark the jaws, but ace for zip ties. Mine are 76 22 125 on this link. http://www.knipex.com/index.php?id=1216&L=1&page=group_detail&parentID=1367&groupID=1481 Share this post Link to post Share on other sites
Weser 30 Posted September 17, 2014 Flush cutting snips are a must for cable ties. Use them all the time at work - I hate catch the back of my hand on the bits when they are not cut flush. My old man has one of these: http://www.justoffbase.co.uk/CVJ-Boot-Tool Expands the universal CV gaiters using the compressor. easier than using the cones. Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted September 17, 2014 MUST NOT be used to cut anything hard as it will mark the jaws, but ace for zip ties. Don't know what you're on about!Yours cut through lock wire just fine Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted September 17, 2014 Don't know what you're on about!Yours cut through lock wire just fine Injury to report, I have just tripped over your gearbox and plate diff I left out for the scrap man when I went to check my cutters.... Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted September 17, 2014 It was essentially scrap from the last time you touched it anyway..... Share this post Link to post Share on other sites
welshpug 1,666 Posted September 17, 2014 I love tools too I'd echo the impact gun as being a massive timesaver, there's no way I could afford to buy one of these beast brand new given their RRP, but the average used price was within reach and around the same as any other cheaper Impact gun I would consider, but this one is even more capable http://store.snapon.com/CT6850-Series-18-Volt-Impact-Wrenches-1-2-Drive--Impact-Wrench-Cordless-18-Volt-Slide-on-Battery-1-2-Drive-U-S--P648625.aspx I find a Power probe a bloody useful tool, though its not used that much so I only got the PP2 not the bells and whistles PP3.http://www.sealey.co.uk/PLPageBuilder.asp?id=20&method=mViewProduct&productid=7224Making brake pipes is a pain in the arse with a £20 tool, so I lurked on ebay for ages to buy one of these.http://www.automotive-toolzone.co.uk/sykes-pickavant-brake-pipe-flaring-kit-270-series-2029.htmlthere are a number of different dies they can come with and you can just buy the tool and specific die alone without buying the master kit which will save you a fair bit. Share this post Link to post Share on other sites
Rich_p 23 Posted September 17, 2014 Does the jump in torque on an impact wrench make a noticeable difference to it's abilities? I see the Dewalt is around 400nm and the Snap On 475n,. I've got a 270nm wrench and it wont even undo wheel nuts! 2nd vote for the Irwin nut grips, they are very handy. Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted September 17, 2014 Does the jump in torque on an impact wrench make a noticeable difference to it's abilities? I see the Dewalt is around 400nm and the Snap On 475n,. I've got a 270nm wrench and it wont even undo wheel nuts! My Dewalt will undo staked in driveshaft nuts so that should answer your question! The tight stuff needs a fully charged battery but thats no great hardship. 1 Share this post Link to post Share on other sites
welshpug 1,666 Posted September 17, 2014 Certainly does, I've used many even with a full charge will not undo driveshaft nuts or crank bolts, where my snapon will do most. Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted September 17, 2014 I find a Power probe a bloody useful tool, though its not used that much so I only got the PP2 not the bells and whistles PP3. http://www.sealey.co.uk/PLPageBuilder.asp?id=20&method=mViewProduct&productid=7224 Tightwad, I have the PP3 Share this post Link to post Share on other sites
welshpug 1,666 Posted September 17, 2014 I know, but its five times the price! I can borrow one if I need to Share this post Link to post Share on other sites
cheesegrater 43 1 Cars Posted September 17, 2014 Another vote for the dewalt impact guns, my favorite tool is the needle nosed belt file made by black and decker. Wicked little thing. Share this post Link to post Share on other sites
welshpug 1,666 Posted September 17, 2014 Have to say this is another recent purchase that I do love, ideal for scrapyard visits or rally service. Granted it doesn't have the grunt of a mains unit and wont last that long under heavy use, but its certainly better than nothing Share this post Link to post Share on other sites
willis 18 1 Cars Posted September 17, 2014 I love my wrecking bar, not on the 205, though! Share this post Link to post Share on other sites
Hheppy 9 1 Cars Posted September 17, 2014 I'm off to find a darkened room, al this filthy tool talk is just too much !!! Mind you, got a few good ideas for what my Mrs can buy me for birthday presents now thanks!! Share this post Link to post Share on other sites
nick205 12 5 Cars Posted September 17, 2014 I quite like tools too. Difficult to pick a favourite, but one thing I really like is having the correct type and weight of hammer for a particular task. When I see people driving nails with an engineers ball pein hammer it leaves me a little agitated. Share this post Link to post Share on other sites
Henry 1.9GTi 36 Posted September 17, 2014 Riv-nut gun - win Drill - nothing more satisfiying than drilling holes in your pride and joy Impact driver - no more rounded off brake disc locating screws Torque wrench - beacuase going around the car making clicking sounds makes me feel like ive made it go faster Share this post Link to post Share on other sites
mrfirepro 127 1 Cars Posted September 17, 2014 Tom, I'm very disappointed, you never told me about a pipe straighter, just about clamping two bits of angle together, if you did that for a bet, I hope it was worth it.... :lol: :lol: the hours I spent with those two bits of angle, they even had names by the end of it.... Share this post Link to post Share on other sites
Tom Fenton 1,548 Posted September 17, 2014 Two bits of angle is how I used to do it. The pipe straightener is a more recent discovery! Share this post Link to post Share on other sites
glenwah 20 Posted September 17, 2014 Snap on techangles are probably my favourite tools, got the 3/8 and 1/2 inch, bit pricey but when you use tools for a living there is no point scrimping. Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted September 17, 2014 Snap on techangles are probably my favourite tools, got the 3/8 and 1/2 inch, bit pricey but when you use tools for a living there is no point scrimping. My old chaps got a 1/2" one and it's very good although...... I have on more than one occasion whilst swinging on it had the end cap come off which in turn lets the batteries come unseated and cuts the power! Dead handy Share this post Link to post Share on other sites
