Hillman.94
Gti Subframe For The Tu Engine
Hillman.94
How easy / difficult is it to mod the gti subframe so the to engine fits I understand you need to mod the gear linkage but don't no a lot only just started to think about doing it
Mat
BERTMAN
I cut the gear linkage bracket off of my TU subframe and welded it to the identical place on the GTI subframe. As regards subframe modification that's it!
You will however need to swap over to gti wishbones, anti roll bar (and associated clamps, bushes, droplinks), and swap over to GTI dampers too.
I have a modified subframe going spare if you want one.
Hillman.94
How much would you like for the subframe I'm already on gti dampers but not going to run the anti role bar as it's for stage rallying
