cRaig
Electric Roof Switch Wiring
cRaig
Ive finished all of the loom for the rear electric window openers, and have got as far as the switch. Does anyone have a pin out, or diagram for the electric roof switch?
I'd like to know which pins are the positive and negative in, and then which are the outputs to the motor. With 5 pins there are quite a few combinations to try and do it via guesswork! :D
Thanks,
Craig
Not sure if it's the same as a window switch, but if it is, the wiring will be as follows:
1. Motor wire 1
2. Earth
3. Switched +12v
4. Earth
5. Motor wire 2
cRaig
Well, the switch visually looks identical, apart from being slightly shorter, so that seems a sensible place to start, thanks!
Which is pin 1 on the switch by the way, as they arent labelled in any obvious way. Im guessing pin 1 is on the lhs on the side where the pins are more visible, with the plug in? (if that makes sense?)
So pin one is on the left side of this photo?
EDIT: the plug is labelled on the other side!! :D Will go test now :)
Edited by cRaig
Weser
Been a while since I fiddled with the roof switch but I am pretty Anthony is right.
When pressed one way Pins 1 and 3 link. When pressed the other way pins 5 and 3 link.
I might be wrong though its been a while. A multimeter should confirm.
cRaig
Yep, its a window switch, and the above wiring worked. Sitting in the boot with both quarter windows opening and closing simultaneously on the switch has brought me great joy! :D
Thanks for your help :)
