Rob_the_Sparky
Be1 Clutch Cable Availability?
Rob_the_Sparky
Spoken to Euro Car Parts and they have discontinued and GSF now only lists one cable, which is for a BE3. Anyone sourced one recently? I could probably recover mine for a while with a dose of oil but will need a new one eventually...
Motaquip certainly still stocked them very recently - last one I got (a BE3 admittedly) was a Dura branded cable identical to OE.
Just remember that there's two different BE1 cables depending on age and changeover was around a F reg.
farmer
Forget genuine Peugeot ones anyway.
I fitted one and the quality compared to the QH one was evident.
Rob_the_Sparky
Ah great Anthony, you have to complicate things, as usual my car is right on the cross over...
Slo
Been thinking of getting a spare for a while and would rather get one when its not needed with plenty of time. Can a be3 one be modded to be1 at all?
I've got a phase 1 e reg cti, no idea on length
S@m
Sadly motaquip have also discontinued both of the BE1 cables;
I recently fitted a Quniton Hazell BE3 cable, so they might be worth a try for BE1...i don't have access to their eCat though.
Edited by Sam306
I do my best Rob :D
Check the fitting where the cable enters the bottom of the pedal box - the earlier cable has a (usually black) twist fitting and the later cable has a (usually white) push in plastic fitting that sits inside a rubber grommit.
Be careful as some suppliers will only list one - usually the earlier twist-fit cable.
Oh, and some bad news - just checked the e-cat looks like Motaquip have deleted both BE1 cables from their range :(
S@m
This one might be worth a look
http://www.ebay.co.uk/itm/PEUGEOT-205-1-6-1-9-Gti-1-8D-309-1-6-1-9-D-Clutch-Cable-BE1-Gearbox-Non-PAS-/380954720836?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item58b2abba44
Can clearly see the end fittings in the picture to compare to yours and there's a few others on there.
Edited by Sam306
farmer
I can get hold of genuine early cables chaps if that helps
When I got a clutch cable in an emergency for my 306 hdi it was a QH bag with a Dura cable in it so there are several sources for an be1 cable from the oe manufacturer but it is very likely luck of the drawer.
g
S@m
Annoyingly, I noticed today that one of the BE3 cables has now been discontinued aswell;
Albeit the uncommon one.
Edited by Sam306
Don't worry Sam - that's the type that I don't think I've ever seen fitted to a 205/309 and which isn't listed/stocked by most other suppliers anyway.
maturin23
Did anyone manage to find somewhere stocking the later BE1 cables?
My 205 is a 1989 model (originally with PAS - now running Saxo electric PAS)
Any ideas?
Fairly sure firstline still do them, most motorfactors around here do that brand.
Rams_gti6
I've got one, brand new in bag bought by mistake. £15 if it's any good to anyone
Karl
Andrew page do them :) but as Anthony mentioned there is 2 types so id take your old one in to be sure
Edited by Karl
Alastairh
Just thought I would update this as I was searching at the weekend for a late BE1 cable for my car. First line do still stock the late be1 cables under pn: FKC1103. Available on eBay by that part number, or by your local first line stockist. I paid £18 for mine at fits a treat.
Al
Alan77
I've just found the Motaquip VVC372 BE1 cable on ebay for £11. Item 400932460012
