arwel
1600 Or 1900 Box
arwel
Evening people. Destroyed my input shaft on the Harry Flatters rally this weekend. I have a 4:9 CWP in the current box which is a 1600 gti box. First is extremely short but acceleration is amazing with a top sleed of around 112MPH which is good.
Am i right in thinking that there wpukd be a better advantage to rebuild the 4:9 into a 1900 box as it has a slightly longer 1st and longer 5th so slightly higher top speed without sacrificing too much acceleration?
5th is the same in both boxes, ie 0.865:1
Biggles
Info I've got says 2nd to 5th are the same in both 'boxes.
<Edit> Link above says this is only the case for BE3 'boxes, the BE1 2nd being different also.
Depending on your engine spec, the longer 1st might lose you a touch but the smaller drop in revs when you change to 2nd might gain you a bit.
Edited by Biggles
arwel
Ahhh right. I though there was a difference in 5th. Never mind then. well stick with what we know and go 1600 again. Thanks guys.
1st is the same in most BE box's although tech info will say otherwise,
