Terry1600
205 Cti Phase 2 Cooling Fan Wiring
Terry1600
Hi there, i have a Phase 2 L Reg 205 CTI which has had an omex ecu removed from it along with the ecu controlled fan setup that uses the 3 pin sensor on the radiator. my question is now that it has been removed i cant seem to find what wires go where on the original 205 wiring for the sensor on the radiator.
can anybody provide me with a wiring schematic so i can trace them back and connect them up as they originally where?
cheers in advance. Terry
The fan loom is completely self contained so it's probably been totally removed. You should be able to get one from someone breaking a car.
