Monkey
Ordering Ht Leads
Monkey
Hello!
I am in need of a little help if somebody has 2 moments please?
I need to order leads for a phase 1 gti - essentially one where the coil is on the wing. The king lead is different for the other coil, which I found out to my cost!
Does anybody have a number plate for a phase 1 car I could use to give a supplier to make sure I get the correct part please?
Thank you!
1.6 or 1.9?
see below for part numbers.
Monkey
It's an Mi16 with Ph1 coil and bolt on distributor.
In short it's a bit of a mixture!
Thank you by the way for your kind assistances :)
Edited by Monkey
oh, afaik there arent any off the shelf leads that fit, ask miles at pugracing as I think he may know a supplier or have some to suit.
Not any more they went a while back, it's Magnecore that do the Mi kit's still
Monkey
Cheers - I have dropped him a PM.
Hopefully he will be happy to assist, thanks again :)
*Edit: too slow - I guess I'll just need to piece something together then!
Edited by Monkey
Monkey
So... Big news! I made it!
160miles driving round Snetterton was completed on Sunday! Was excellent fun...
Does anybody happen to know which spec and size silicone joiners I need to mount my R1 carbs to Bogg manifold? This time there will be a bracket, these will just be joiners for the fuel and air... it seems I neglected to notice the complete lack of bracket as they hadn't fallen off on me before the track day!
Also the little foam filters, 1 per carb... they're not so good, got sucked in a bit - but they're combustable and no hard was done happily, they're mostly still there - but being replaced for something better before any more driving.
309s are sooo much fun on track!
