brian j
How To Fit Steering Column Rubber Grommet?
brian j
I feel like I'm missing something here...
Since I bought the car the steering column rubber grommet in the bulkhead by the clutch peddle has been loose, not in its hole.
I have had a few half hearted attempts to fit it back with no success so at the weekend I thought I'd give it a proper go and it has defeated me. I can't get it back in. It looks to be in good condition. I have tried lubricating the lip and pushing from the inside/pulling from the outside with no joy.
How do you guys manage it please?
I'm a little embarrassed that I would happily strip and rebuild most parts of the car but can't work out how to fit a grommet...
B.
I think the trick is to install it without the steering shaft through the middle. Allows you to manipulate it that bit more .
As above - much easier doing it before the lower column is in place.
Not what you wanted to hear having fitted the PAS rack etc already I'm sure :lol:
Stu
Eurgh. I need to do mine and not only have i refitted the column, but all the plastics too.
FML.
You only need to remove the lower column
brian j
No need to look so :lol: Anthony! :D
Oh well, at least the dash plastics etc are still out. I'll pull the lower column out and see how I go with it.
Thanks all!
ftoomsh
Plenty off LUBE!!!!!!!!
took me about 3 hours. would have been much easier without column in!!
