mrfirepro
Engine Machine Shop, London And South East
mrfirepro
Looking for another engine machine shop to do skimming, pressure tests, cranks, balancing, piston builds and cleaning & preping.
Can anyone recommend anyone they have used, the look of the final product is important to me.
for balancing http://vibrationfree.co.uk/ is pretty much the best in the Europe and will have much better results than the normal engineering company, Machine work Sutton Rebore are good and have been around as long as my Dad, LOL a long time
mrfirepro
thanks guy's, that's a good list.
shalmaneser
I found Board Bros by Clapham Junction were pretty good when I got my head skimmed and rebuilt if you need somewhere in London!
GilesW
Absolutely agree.
Steve is the best (and just round the corner from Helix if you need a clutch too).
Not the cheapest but certainly the best.
Sutton Rebore do SBD's engines and are excellent too.
Both did my vauxhall engine and I wouldn't hesitate to go back for my XU engine.
mrfirepro
Modus Engine Services in Tunbridge Wells had my engine, but I decided to take it back after appalling customer service, if anyone was thinking of using them I would steer clear.
Edited by mrfirepro
2-Pugs
Might be a little but far away from you but I have used Roe Engineering in Fleet for head skims and rebuilds. Can't comment on other engine work but the guy is proper old school and has always done a good job for me.
MikeC
Can vouch for these too, have done cnc spindle assemblies for the company i work for.
mrfirepro
As the car is going to be a standard road going car would it be worthwhile getting the rotating mass balanced as it's nearly £400, not really sure about the benefits for a normal road car.....
GilesW
None.
They were 'balanced' enough out the factory that if you are running a complete OE engine and predominately on the road then I wouldn't bother balancing it at all - the OE standards will be fine.
'Proper' balancing is really only of worthwhile benefit if you are upping revs and/or sustaining high revs - which you won't be.
Spend your £400 elsewhere on the car.
