ASBGTi
Caliper/hub/drive Shaft Identification
ASBGTi
Evening all,
Is there any way of identifying what calipers/hubs and driveshafts I have on my 205? It started life as a 1.6 and has been converted to a 2ltr mi16. I am currently overhauling the brakes and suspension and am in the process collecting the bits for a gti6 brake setup. Before I start buying hubs and drive shafts I want to check what I currently have.
Any help will be greatly appreciated.
Look at the disc offset
At a glance if you have 1.9 hubs you'll have a different, larger hub nut, usually with a locking clip rather than the staked hubnut found on base & 1.6 models.
Another way to identify 1.9 GTI hubs is they have two cut outs opposite each other in the drive flange.
g
ASBGTi
Ok thanks,
I'll get a couple of pictures posted up later, that should put it to bed.
ASBGTi
Right, correct me if in wrong but I'm fairly sure these are 1.9 calipers which I understand fit on either 1.6 or 1.9 hubs.
So what hubs do I have.....
Edited by ASBGTi
Have a look at the article on hubs and brakes on the main website, dimensions of the discs are in it.
That is a 1.9 caliper.
has the castellated nut and r-clip that only the 1.9 used, thread is m24 with a 35mm nut.
Edited by welshpug
ASBGTi
Thanks pal
ASBGTi
Right,
Based on the brake article I have 1.9 brake discs. So, can I now just bolt on my gti6 brake discs and calipers?
Also I am after some braided hoses, will I need 205 hoses or 306 hoses?
dcc
Extended 205 hoses
ASBGTi
Extended 205 hoses
Cool, know where I can get these?
kam racing or pugracing.
dcc
or standard hoses with copper extensions
ASBGTi
Thanks all!
Finally, I have a set of 1.6 bearings in the garage, will these fit?
No.
g
1.9, you can see the cut out in the drive flange I mentioned in your pictures also.
g
ASBGTi
1.9, you can see the cut out in the drive flange I mentioned in your pictures also.g
Marvellous!! Thanks everyone!
