mrfirepro
Mercedes Ml Wiring Diagram
mrfirepro
I have a 2006 ML500 that has faulty brake sensor wiring, been looking for a wiring diagram so I can run a new brake sensor wire but drawn a blank.
Does anyone know where I can get a wiring diagram from, it would be a really big help.
Edited by mrfirepro
alync406
I can get you a wiring diagram but it won't be until Tuesday.
Is it for the brake wear sensor? Is it a W164 ML?
If it is for the brake wear sensor and a W164 it more than likely goes to the front SAM which is located in beside the battery. Sometimes these can get water into the connections which cause problems.
mrfirepro
Anthony,
That would be great help. I had to take it from Mercedes as they have already had it for a whole day, charged £300 and told me it could cost upto £2000 to find and fix. They also said they suggest testing the loom down to the wheel.
I removed this loom tested it myself to find it was absolutely fine.
It is a W164.
Funny you mention water, found the engine bay fuse box housing (O/S engine bay) half full of water with two multi plugs almost in the water.
Will PM you my email address
