Juttie205
Paint For Underside Of Car
Juttie205
I'm in the process of stripping my car to bare metal on the underside and will be etch priming and then using stone chip what im after is where to get primer and paint(cherry red) thats safe to paint at home many thanks.
For a durable coating you really want something that is 2 pack e.g. has a hardener in it. The main hazard to health from this comes from inhaling the fine overspray. So one way around this is to mix up then brush it on to the car. You still should wear a decent mask, but at least you don't get the airbourne spray everywhere.
I have an air fed mask so I sprayed it on.
Juttie205
Thats what I thought trouble is air fed masks are so expensive and would only need one for doing underside of car.
nick205
Worth paying someone to do it for you?
Lowercase
just brushing it on will be a lot easier and save yourself a lot of mess. you'll have stonechipped it so i wouldnt get too precious about the finish. just get it on there nice and thick.
Juttie205
Might sound strange dont want a brush finish on my car
Lowercase
over a stone chip finish you wont be able to really tell, 2k paint is great stuff, kind of gels together and goes glassy.
i can understand though, i share your OCD levels!
205wrc
Forget stonechip. If it cracks and starts to peel, water will get inside it and get trapped. One of the best stuff on the market is this http://www.ebay.co.uk/itm/U-pol-Raptor-Tintable-Tough-Urethene-Coating-Truck-Bed-Liner-Kit-Trailers-/110785795320
It's much stronger than stonechip, and tintable to the colour of your car. A lot of road rally cars are using this now as it's much harder wearing than stonechip or Hammerite
Juttie205
Does look like a good product where would I get the tint from?
Its 2 pack so you are back to needing the air fed mask!!
Juttie205
All video's of people using it are not using air fed masks so now confused.
205wrc
You'd be able to get the tint from a local motor factors, body shop, or paint suppliers. Everyone that I know who have used it do not use air fed masks, as it's basically stonechip / underseal
stu8v
It will be carcinogenic. Your call most 2pack stuff is.
Use a mask.
Generally if you put a catalyst (hardener) in then you need an air fed mask.
Juttie205
Think im gonna keep a eye out for a air fed mask can anyone recommend where the best place to paint from aswell
