willis
Driveshaft Noise
willis
Hi,
My 1990 1.6 has a noise and judder felt through the steering wheel which happens when its turned (more one way than the other) but it's not felt in a straight line.
I think it's the driveshaft (correct me if I'm wrong) and I just wanted to check before ordering a couple more.
PAGOS
Check the bottom wishbone inner bushes and outer ball joint .Turn your steering from lock to lock and check for free play on each side .Also , as you move from lock to lock put your hand on the coil spring and feel for any vibration .If so then check the top mounts .
willis
I'll give this a go. Thanks
