dobboy
15" Sl's - What Wheel Spacers? (If Any)
dobboy
Howdy, do any of you guys know off the top of the head what wheel spacer thickness i would need to run 15" GTI SL's ( with 195/50/15) on a CJ?
Do i even need them at all?
calvinhorse
None at all just the gti bolts
dcc
not so sure Cal, because the hub offset is different on the base model, so the wheel sits closer to the strut on the front. I know I had a set of SMr's on a 1.8 diseasle without issue though, but not sure what hubs they used.
dobboy
Thanks Calvin!
(another few bob saved!)
calvinhorse
I had a xs gti rep, they fit fine, backs are tight on the outer arch, front certainly doesn't need spacers
dobboy
I had thought from various old threads that i would be ok at the front, and any problem would be at the back, (due to the GTI/standard arches being different..... but thinking about it, the 1.9 has discs, so the back end could be different in that respect also.
calvinhorse
Base model hubs are the same dimensions as a 1.9
A diesel is the same as a 1.6
calvinhorse
Trust me, you don't need spacers
dobboy
Great.
