gtiburge
Phase 1 And 1.5 Brown Plug
gtiburge
hello
i am in need of a photo of the brown plug under steering wheel of a phase 1.5 or phase 1(think there the same ) car as i am trying to reconnect up the loom as the car used to have a gti6 engine in it and i am going back to 1.9 8v photo would b better as i cant seem to find any numbers on the wires, or a diagram listing wire colors would be good
thanks
olly
mikeyd
if you want to look at an f plate one pm me for contact no -- am at sturminster newton
Grim.Badger
The attached shows a G-reg P1.5 setup. Note that the starter solenoid wire and coil wire can be switched around for no apparent reason. Also, the Tachometer wire can be found as a blue wire numbered 112 and coming out of the smaller plug instead of the larger one.
If memory serves (which is a big if) the P1 had the same dash setup, but lacked the engine bay multiplug.
Edited by Grim.Badger
