gizzmo
Vin Decode Help Date Of Manufacteur
gizzmo
Hi any body help me with date of manufacture for my car.reason being the cat test,it's registered as a 93 but from what I have read the use date can de also judged as the date of manufacture if it's greater than 6 maths fro date of first registration considering the vehical may have been stored before being sold any comments?
gizzmo
Thanks for the replie don't seem able to connect to service book
you need to create an account, anyone can do that.
gizzmo
will do thanks
oak tree garage
you will find that mot station will have to match model and engine code with the data base on the gas analyser info supplied by vosa to determine weather your car is non cat test or cat test required. this is from manufactures data hope this helps
gizzmo
you will find that mot station will have to match model and engine code with the data base on the gas analyser info supplied by vosa to determine weather your car is non cat test or cat test required. this is from manufactures data hope this helps[/quote. engine nos not available,so hoping to get away with car build date
gizzmo
Just had a look on service box but can't seem to locate date of manufacture,any help would be appreciated ?
