scbond
Unknown Disconnected Hose And Wire
scbond
Need help identifying a couple of things. First (first image) is the small hose that enters the header/expansion tank at the cap. I found that it was loose at the other end today. There's no fluid in it and I've not been losing any coolant so I'm assuming it's a vapour return or something? Can someone tell me where the other end connects to as I haven't got a clue?
Second (second and third pics) is a cable/wire which I found dangling behind the front nearside wheel, near the wishbone/driveshaft/caliper. I think it's for the pad wear sensor but can't be sure. It enters the cabin through the firewall behind the strut with the loom.
MikeC
The hose is just an overflow, and is not connected to anything. The cable looks to be the wear indicator earth that is strapped to the top of the strut. Maybe check it electrically with a meter to be sure.
scbond
Ok, cheers. So the hose is meant to be as I found it...just dangling and aiming at the ground bind the gearbox? As for the wear indicator wire...I can't actually see any copper wire in it and it feels spongy when I squeeze it. The only way I knew what it was (sort of) was because I saw similar looking wires tied in a knot on the other calipers (obviously because someone didn't bother with compatible pads). Does it normally plug into the back of a compatible pad?
MikeC
There should be a socket near the strut above the pad carrier. Can you follow the cabel, just ya said it was spongy.
The pipe aims for the ground :ph34r:
scbond
Ok, will have a look tomorrow. Can't really get under the car properly as I don't have a jack or stands with me here in Nottingham. If there's no sensor compatible pads in the carriers I take it the wire doesn't need to be connected? As far as I know all the others on the car are just tied up near the calipers.
MikeC
It just earths when the pads wear and brings on a light on the dash
scbond
Ah ok...think I'll just tie it back somewhere as I can't see myself ever bothering with getting the right pads over normal ones when you can tell when they're worn anyway :D
