scbond
Remove Headlight/indicator In One Piece
scbond
Does anyone know if there's a way to remove the headlight and indicator in one go? Some idiot in the past has broken the adjuster and then fixed it with a cable tie which I can't reach to cut free and obviously can't get to the indicator securing screw until the headlight is fully out. Can they be removed with the adjust all in one go?
only if you can get at the screws for the mounting bracket, which invariably are corroded and need the heads drilling off.
with that in mind I doubt it.
scbond
Hmm...I'll have to have a closer look and see if I can get a longer knife in or something. Either way, the adjuster needs replacing.
Thanks for the reply.
