Gavin Waddell
Grey Bumpers To Black ?
Gavin Waddell
I've got the possability to get some grey bumpers but would really like black ones has any one changed colours in bumpers?
I've got acces to a private painter and done some prep work before so that sing a problem
Gavin
Plasticare will do it reasonably successfully even though it's not really meant to be used for that purpose.
Swap you for a black one if theyre good!
You have seen his location haven't you Mei?
Gavin Waddell
Yeah live a bit far away for swaps. Ok do plastic are should do it woohoo.
Gavin Waddell
Arwing
Use platicare. Even though it says it's not intended to change the base colour. It does do it. Only prep work you need is a good clean. Once dry, apply 3 coats with a piece of cut out sponge using a dabbing method. I didn't even use half a bottle using 3 coats on both the front and rear bumpers. The effects last indefinately too. Applied over 6 months ago and they're still as black as ever. Here's the results...
Before plasicare
After Plasticare
iPlod999
Not a Pug. However, 2 coats to this
To this
To finally get this.
Gavin Waddell
Cheers guys that has sealed the deal for me, now just need to buy the bumpers. Thank you very much.
Gavin
