5mudge
Help School Boy Error
5mudge
I've stupidly forgotten where to mount the rear brake lines. Can anyone help me please
Henry 1.9GTi
one on lower damper bolt. The metal plate is shaped so that it fits and wont turn on the trailing arm when tightening the big damper nut
one on caliper bracket, metal plate has a little tab which sits on top of trailing arm so stop the thing turning. Small m6 in the back of the caliper bracket
inbetween these two points is solid line. With flexi either side.
mrfirepro
handbrake cable should be under the bracket and those pipes.
mrfirepro
good spot thanks..was also wondering if I should use two clips for the two holes??
Yep :)
dobboy
Nice carpet!, do you wear a cravat when working on it?
5mudge
Lol... Just bought a house and we are changing the flooring.. I put the underlay underneath also. Was nice n comfy though
omega
you would have got more" man points" if you had said you where doing it in the front room!!
I'm building gearboxes and an engine in the front room :ph34r:
