Rich_p
Helper Springs
Rich_p
I am going to swap the 8” springs for 7” springs on my coilovers. Due to the short springs I imagine I am going to need to run a helper spring just to ensure the main spring stays seated at all times.
As they will be coilbound when at normal ride height I know I will need a lowish spring rate but am unsure on whether to go for the 4lb or 30lb versions.
I’m concerned the 4lb springs won’t provide the necessary support.
Does anyone have any experience with them?
johnnyboy666
I use 30lb ones and would recommend them. Im not sure if the 4lb ones would be up to the task, I envisage them being lke the spring in a biro
stu8v
As above.
I previously tried the lighter ones, they never worked for me.
Rich_p
Thanks for the answers. Now to track a set down..
allanallen
Is this for tyre clearance with your new hubs rich?
If it is you may find you need 6" springs, the helper will still be around 15mm tall fully compressed so may not give you sufficient clearance.
Rich_p
They were to ensure the springs stay seated, I assumed being shorter they may move about.
I need to set the front an inch or 2 lower as well to match the rear.
I hadnt even considered clearance with the new hubs may be an issue.
JeffR
On my 405 with GAZ coilovers, I had 7" springs with 120mm custom helpers to keep spring tension throughout the full suspension arc. The spring platform needs to be almost level, or higher up than the tread to clear the inside of the tyre.
Henry 1.9GTi
helpers are only to stop dislocating when working on the car and occasional curb bouncing. Shouldn't expect it to dislocate in cornering and if it does you will loose roll resistance across the front axel. Going for a tender which I assume are the 30lb plus ones they will be quite thick I imagine so need to work out ride height.
As per allans comments you may not be able to lower the spring seat below the tyre so worth thinking about helpers effect on ride height. I run 5.5inch springs with a helper that has no effective spring rate. Works fine. Total thickness with the connecting seat / coupling is ~15mm coilbound
Also ran the car for a season on longer spring with no helpers that dislocated. Was fine again, just got to be careful when lowering it back down off the jack
Edited by Henry 1.9GTi
Rich_p
it looks like I need to get the new hubs fitted then check clearances before I go and start buying anything else.
Thanks for the advice.
