rallyeash
Shenpar Rose Joint Wishbones
rallyeash
Hi,
I'm thinking of buying a set of the Shenpar rose jointed wishbones, has anyone had experience of them? I assume they are jointed on the inner subframe mountings too like the picture opposed to standard bushes and a rose joint BBJ?!
http://www.shenpar.com/interimshop.php
I want to convert to jointed inners over standard bushed wishbones as I can't seem to keep the car in a straight line under power! I've used gen pug ones for a while and just tried super pro Polly bushes and I couldn't drive it properly at Combe on Saturday. Under power it wanted to turn aggressively any which way but straight!
my thought process is that joint inners will solve my issue.
Ash
they look like Compbrake items.
seeing as you have new bushes, it sounds more like a setup issue.
Edited by welshpug
rallyeash
I did the tracking afterwards and set to parallel.
dcc
Are you running a plate diff?
I don't have any issue going in a straight line when giving it some beans.
Could you have play in your steering column somewhere?
(I've a plate diff, Jeff Skitt lower arms, set parallel, stiff rear end ~ 28mm arb, 21mm TB's, agree'd I don't have your BHP, but I do have some fun torques!)
rallyeash
Yeah Tran X diff. No play atall in the rack, have changed to VTS rack though.
You've just fitted on some adapters to relocate the track rod pivot point, take those off and try it.
B1ack_Mi16
Should be possible to get it to run straight under power. Even mine started doung it when tracking was set correctly :)
But of course if the road surface is really bad it's not gonna happen.
Never run them at Parallel, I like to use Toe out makes a good differance
rallyeash
Think I'll try a touch of toe out.
I'm still keen to eliminate wishbone bushes in favour of a non flexible rose joint.
Someone must of ran the shenpar ones?!
did you not see my post? :lol:
rallyeash
I did notice they look a similar design but that doesn't mean there equally as bad as compbrake! Is there any other manufactures that use joints on the inners?
yup.
:P
rallyeash
I know! Looks awesome too! I've driven my mate Craig's 205 (grey one I did a project thread on and has Colin's full setup) and been out on track as passenger and it's a lovely setup. Wet grip is awesome but I guess that's down to getting it all working at the correct angles and then making it softly sprung cause you can!
Exactly that, the full package is addressed not just individual components.
blandy
I take it all Colin's stuff is priced individually etc never seem to find much pricing info just lots of awesome pictures of what he does
rallyeash
Call him is the best bet.
His business is more people to people than Internet selling.
I think his front setup is circa £1500 but don't quote on that...
Colin usually does all the work himself as a package.
I'm not sure they have anything off the self as such for a 205 as there's so many variances, but they have done this for the 106/saxo, which is also available as a wide track kit, other than the strut top plates and strengthening braces its a bolt on kit.
What you see in the pics is £2k iirc, plus fitting, add your damper insert and off you go.
Edited by welshpug
blandy
Wow that looks special that man is a genius
