AdamF
Can I Run A Standard 1.9 Gti Exhaust With A Gti6 Engine?
AdamF
Non cat if that makes a difference.
Is this possible?
Adam
mech205eng
The 1.9 downpipe will need modifying to mate up to the gti6 manifold. But it will work fine, it won't restrict a standard gti6 engine at all
The exhaust can restrict the engine depending on type, you need at least a 2" system with them. But basically the D/P is shortened and a lambda boss added is using OE injection
dobboy
I measured a spare DP i have, which is part of a 3-piece system.
It starts life at the manifold clamp at 2.5" internal diameter, and ends at 1.75"
Is this ok for GTi6?
Earlier 3 piece systems are typically narrower and more restrictive.
At 1.75" ID I would personally say that would be restrictive to a GTi-6 engine, in line with Miles's comments above.
The later 2-piece systems are typically a little over 2" ID (although it pays to check as not all are!)
