max0
Once Bitten...
max0
Not been active on the forum for a few years. See a few names I reckonise are still around :)
Back behind a white GTi. She pasted her test at the start of the month. Done about 800 miles so far without any major issues. (apart from the petrol bill)
Cheers Andy
Edited by max0
Welcome back!
Your 205 looks nice but you should put some orange indicators on it ;)
max0
  On 4/20/2014 at 3:24 PM, jackherer said:
Welcome back!
I've got some orange side repeaters to go on. Not sure if this one should have orange fronts as well?
certainly should if it has those rear light clusters.
max0
Cheers I'll add it to the list :) got a rear wheel bearing to swap, crack in the manifold, and clicky starter wiring to resolve
jord294
I'd advise a 306 gti starter, as it's slimmer and gives a better throw when cranking.
max0
Cheers, I swapped over the starter (both fat old types) and the clicking remained. Need to get the volt meter out. Read the relay trick.
Daviewonder
It'll probably be the brown multi plug near the gearbox.
max0
I've not had a good look yet, but i think the solinoid wire goes straight to the fuse box.
Is it an early one? pre 1987 ish? They don't have brown multiplugs and the wire is routed on the passenger side which sounds like what you've found.
Cut the connector off and if the wire is anything other than shiny copper cut more off until it looks good, you might end up very close to the bulkhead. Then splice some new wire in, either solder and heatshrink it or preferably use a solder sleeve.
max0
Its a F reg so 88? I think the previous owner has replaced the wire as it doesnt look standard.
I've swapped the starter for a old one I had in the garage and didnt have issues with on the last car but it has been in the garage a while. Tried another battery of my daily drive. Sometimes it clicks / sometimes it starts first time. I'll clean the earths up tomorrow and have a look with the volt meter to see if i can find a voltage drop.
Tempted to buy a new earth strap. Will see if it improves using the jumper leads on the block / battery
If it's an F reg it is definitely a bodge. Test the starter (and ground wiring etc) by holding a wire to the battery + then touching it to the solenoid connector.
m_john_m
Looking good mate! I'm Dieing to get mine on the road :D
max0
cheers :) been the best three weeks driving it after work... Got much todo to yours?
max0
Good idea hadnt really thought of that. I'm guessing I need to turn the key to postion 2 and + to the solenoid and it should start?
Daviewonder
No, just a wire from + to solenoid.
Just do it with the ignition off and it will (well, should...) turn over but not fire up. Just make sure it's in neutral first or you'll run yourself over :lol:
max0
is the solnoid the starter trigger wire or the main voltage terminal? I wouldnt have thought putting + to the trigger wire would make the starter spin over with the ignition off?
Edited by max0
The solenoid is the smaller wire on the starter, when you turn the key power goes to that wire and the starter turns. It will still do it with the ignition off but like I said the engine wont fire.
max0
Many thanks.
m_john_m
It's not ticking over and it needs a service and mot. I can insure it next week so IV got a week to get it ready :P
max0
Good luck with the mot :)
Had a spare hour this morning to check out the starter... With a cable direct to the battery + it turned over every time without clicking. Kinda gutted I spent ages changing the stater over now. You live and learn.
Followed the command / solnoid wire back to the glove box and found this...
Urggh! At first I thought maybe someone has wired up a relay but cant find one. Only one wire comes out of the black connector so not sure what its for.
After going through all that (and more near the starter) the wire ends
going into the last wire on the right hand side on the first yellow connector. (light blue and with the blue connector on it)
Is that the correct location on the fuse box? and can i remove that fuse (doesnt look standard) Hoping I can just wire in a whole new cable and see if that improves things.
Andy
Edited by max0
It's hard to know where to start with that, the blue fuse thing is non standard for sure.
I just took this photo of mine but it's a phase two so not quite the same:
max0
Had a search on the forum. The light blue wire looks wire 46 the correct solenoid wire :) I guess it's not normally fused? If not ill rip all that other s*ite out.
No, the only fuses that should be there are the ones plugged directly in the fuse box.
