gtiburge
Gti6 Back To 8V Clutch Options
gtiburge
i have just put down a deposit on a 205 wit a gti6 engine in witch used to be in an old car of mine and the gti6 engine is f****d and i want to put the std 1.9 8v engine back in it my question is it has 1.6 gti box in and i presume a mi16 clutch i no the clutch to b a good quality luck item and very healthy as miles original done the conversion on the old car would the mi16 clutch bolt up to the stander ed 1.9 8v flywheel i would put a new clutch in but am on a very tight budget and just need it on the road help much appreciated
cheers
olly
jdt
Mi16 flywheel / clutch is 215mm diameter, 205 8V is 200mm dia so cannot mix and match
if the clutch is still good then bosh the 215mm flywheel on an 8v engine with the MI clutch.
its what I've run on my 1.9 for a few years due to running a crank sensor.
gtiburge
So the gti6 flywheel will fit the then ? What about the weight is it heavier as don't want to loose the revy engine ?
Its a bit lighter than a 1.9 flywheel, i doubt you will notice.
