niv1812
Dta Base Map For Mi16
niv1812
Hi guys,
I'm new to the forum and i wanted to know if anybody can help me to get a base map for the DTA S60 and the DTA E48 for the MI16 as I have two cars with these ecu's and it's password protected. I would like to load a base map and tune the car. My issue is that I'm new with the MI16.
Thanks a lot for your help.
cheers,
Niv
niv1812
Hi guys any update please :)
huwjones
If the map is password protected, I don't think you will be able to load a new map either. There is a 'master' password that can be used to unlock/reset previous passwords but I think that will be dealer only, unless it has turned up on the internet somewhere.
There is a factory base map that can work for the Mi16 - it will be pre-loaded in the DTA software. I think it's either a Vauxhall 16v base map or Golf GTi - both have similar injection and coil setups as the Mi16. You might have to change the flyweel pickup though (XU9 will be 60:2 I think).
My map won't be any good to you as it's an XU10 with twin coils.
huwjones
Oh, and are you using the standard Mi16 idle valve? If so, I think the vauxhall engine uses the same valve.
Jonny_205
I'd give Martin at mefmotorsport a call, he's very helpful.
John
kyepan
i have one for an s40pro if that helps, it only goes up to 5k rpm but is suitable to go to the mappers.
RallyeP6
Bonjour Niven,
I have a DTA E48 map for a Gti6 engine running throttle bodies. It will be good enough to start, idle and drive your car, are these 2 rally cars?.
Oh just noticed how old this post was.
