pp205
Goodwood Interior Into A 205
pp205
Evening,
I have got hold of a Goodwood interior from a broken 5 door Goodwood. It has the standard non tilt seat frames. Are the 309 tilting seat frames the same as the 205 ones or are they slightly wider? Also do they bolt straight into a 205?
Simon
Rock Lobster
I have fitted a set to my last 205, you need to make up small adapters to mount the 309 seats on the 205 tilting subframes as the seats are a little bit wider than the 205 ones.
From memory I used some thick steel plate for the brackets, it was some time ago now though! They are now being stored in the loft until I can be bothered to fetch them down and sell them!
Ryan
The 309 uses the seat frames from the 405, so they're slightly wider than 205 frames. You can fit 205 frames if you make some small brackets.
pp205
Thanks guys!
