dobboy
Jack Position With Air-Con ?
dobboy
Hi, could someone tell me (even better if they can show me), where the jack is normally stored if the car has air-con installed?
I assume it's in the boot?..... is it fixed somewhere by a boss?
(i need to find a new home for mine, away from the OS inner wing).
under the passenger seat iirc, same as a CTI possibly.
2-Pugs
There is a boss welded to the frame for the long screw to screw into, which cars that were not originally air-con equipped may not have, and the carpet has cutouts so the jack can fit there.
It's the same jack as used on the CTI.
Edited by 2-Pugs
