p1234 22 2 Cars Posted April 5, 2014 While out on a track day last weekend I noticed the back end started to walk a bit around a fast right hander, Pulled in and jacked up the back of the car only to find I could pull each wheel outward by an inch or so, got around to stripping it today to find this: The rusty looking one is a standard 1.9. I could try welding the broken splined piece back on along with the end plate but I don't reckon it will last long. Share this post Link to post Share on other sites
Daviewonder 533 3 Cars Posted April 5, 2014 I'd say being able to pull the wheels out by an inch or so is a totally different problem as the ARB has no affect on this. Share this post Link to post Share on other sites
p1234 22 2 Cars Posted April 5, 2014 I run coilovers on the back of my 205 which does away with the torsion bars, it was definitely the problem alright as ive fitted a standard one for now until I source another bar and it has everything nice and tight again. 1 Share this post Link to post Share on other sites
johnnyboy666 195 1 Cars Posted April 5, 2014 How are your trailing arms held on? I would've thought there'd be more strain on the ARB if theres no torsion bars in, as the arb would be the only thing really to hold the trailing arms in? Unless you set up is different to how I'm imagining it Share this post Link to post Share on other sites
welshpug 1,646 Posted April 5, 2014 So you have nothing at all setting the clearance on the trailing arm shaft seal? Share this post Link to post Share on other sites
p1234 22 2 Cars Posted April 6, 2014 Here is a shot of the rear setup on my car, The arms have been completely modified to take the coilovers and thus removing the need for torsion bars. Share this post Link to post Share on other sites
chipstick 382 1 Cars Posted April 6, 2014 Just the end flags hold the trailing arms on? Share this post Link to post Share on other sites
Slo 283 1 Cars Posted April 6, 2014 I've always wondered how the axle stayed together when using coil overs as I always thought it was the tb's that "held" the arms together in place. If you could pull your wheels out by an inch your outer bearings could be knackered not to mention the seals, hell your lucky the arms didn't just fall off the shafts completely. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted April 6, 2014 Get a ARB made with 306 splines, These are a fair amount larger so will reduce this risk, Just need a pair of 306 end plates Share this post Link to post Share on other sites
p1234 22 2 Cars Posted April 6, 2014 Would a weld hold the piece back on and weld the end plate onto it aswell? The reason im reluctant to bin it is because the arb has a bend in it along with the tube. This was done to create negitive camber on the back wheels. The car came with this setup. Share this post Link to post Share on other sites
wicked 103 3 Cars Posted April 7, 2014 Maybe remove the splines of the torsion bars and put them back in as well. Then you'll have 3 bars holding it together iso 1. Share this post Link to post Share on other sites
