lapr
406 Hdi Clutch Prices..
lapr
Hi all,
what sort of money am I looking at do get the clutch done?
Its a 406 hdi 90,without dmf (handy!) on a 53 plate.
A pal of mine reckons I wont get much change from £500... Is this true?! That's got to be worth more than the car itself!!
Anyway, any info gladly received!
GSF list a clutch kit at £116 (o.e.m is £234)
Its a 5.6 hour job according to Autodata, so depends what the labour charges are in your area.
alync406
Clutch kit from eurocarparts for luk is £87.60 or a cheaper one for £63.60 http://www.eurocarparts.com/clutch-kit
Have done a few of these clutches including my own car at the time last year and they are a easy clutch to do, had it done in less than 3 hours. Think autodata are very generous on there times for this job. Hopefully you will find someone to do it at a reasonable price cause the clutch kit isn't expensive.
hoodygoodwood
Have a good check of the clutch before you go to the hassle of changing it , I did mine on my 406 estate HDi 90 last year . I paid about £90 for the clutch and did it myself using an engine support bar from Machine Mart . The 90 BHP version has a solid flywheel and no intercooler so there is less to go wrong .These cars have a hydraulic clutch and my pedal can sink a little every now and then , I just put my toe under the pedal and lift it up to the top . I have looked for a clutch master cylinder and they are not that expensive but the car drives fine most of the time . Check this is not the cause of your low pedal / difficulty engaging a gear etc . Would be a lot easier changing that instead of the clutch !
Do you have to type in BOLD all the time??
lapr
Hahaha, love starting a domestic...
No need to check it, its gone completely! Has been on its way for a while but as its the mrs motor, havnt had a lot to do with it... Until now that is when its broken!!
Its lasted a year like it so it hasn't done bad if you look at it that way! hahaha
£375 all in is the best price as of yet...
Whereabouts in surrey?
lapr
Im in Chertsey.. That quote was from a garage in Egham!
lapr
All done and came in a bit cheaper! :)
£340 all in!
