Bobbafett
Slipping Clutch?
Bobbafett
My GTi 1.9 has started revving up high before speed increase in all gears apart from first. It's fine if you drive if 'normally', but if you put your foot down the revs shoot up to ~4k before the car pulls or increases speed. It does it in every gear, seems to get worse with higher gear but doesn't seem to do it in 1st at all?
Any suggestions?? Logic tells me it's the clutch started slipping but surely it would be worse in 1st if that was the case?
Slo
No it works the other way round, in first it is very easy for the engine to pull the car, in top gear the engine more or less turns the same speed as the road wheels so its a lot harder (and why it judders if the revs get too low when you labour it/stall at junctions etc). How high is your clutch pedal in relation to your brake pedal? Have you tried slackening off your cable?
Bobbafett
It is fairly high but not right up the top. How do I go about slackening the cable?
I have ground the clutch it a few times (sometimes it doesn't want to go into third) and I do boot it around quite a bit. I have smelt burning clutch a couple of times when a gearchange has gone a bit wrong!
Edited by Bobbafett
Slo
If its adjustable it will have two locknuts on the end of it. Crack them free then slacken the cable a bit then retighten them against each other.
Bobbafett
Could that give the same symptoms as this though? I have ordered a Valeo clutch kit in anticipation of having to change it!
Where is this cable, entering the gearbox I assume? I am verging on clueless about engines.
iPlod999
It's on top of the gear box.
I adjusted mine the other day.
If you remove 2 air pipes. 1. Leads from the air intake to the air filter. 2. Comes out the bottom of the Air Flow Metre.
Then you should be able to see it and reach it with a 10mm spanner.
Edited by iPlod999
Slo
Yes as the clutch disc gets thinner the clutch springs will push on the release bearing more thus tightening the cable and pedal rising more.
The clutch release arm is almost directly under the battery. Is yours a be1 or be3? Reverse next to first or under fifth?
Bobbafett
It's a be3, reverse is under 5th. So remove the battery and i'll find the nuts?
iPlod999
Not the battery the tray will be in the way.
If you have slim arms and hands you could reach them without moving anything.
Slo
The nuts are on the end of the cable, well almost the end but this is looking down the side of the battery
Edited by Slo
Bobbafett
Nice one, will have a look tomorrow and see if it makes a difference.
Do you think it might be worth getting the clutch changed anyway? I've looked at the process and don't think it's something i'd attempt myself but got a pretty good price from a garage.
Slo
How many miles has it done and what year car is it? not that that will make any difference, if the clutch is slipping and you have a high pedal and when you lower it by adjusting the clutch possibly stops slipping its a pretty good sign its near the grim end so yes I do think it would be worth doing, also while your there you might as well do the crank seal behind the flywheel. :)
Bobbafett
It's a 93 with only 60k. It's just a weekend car so when I drive it it gets driven pretty hard.
Got the Valeo clutch coming and a decent price to fit so might just leave it myself and just get the clutch done
m_john_m
How much is a new clutch? An uprated one for my focus is about 790 supplied and fitted
Bobbafett
Whaaat, if it was that much I'd definitely do it myself!!!
80 for a Valeo clutch kit and 200 to fit. Not bad considering you have to remove the gearbox, driveshafts etc! The owner of the garage owns a 205 gti so it should be in good hands too.
Slo
Paid £25 for mine off ebay a year ago and fitted myself been fine so far
dcc
Somebody on the forum could help you fit it I am sure. £200 is quite a lot!
Bobbafett
I thought that was not a bad price considering. Read around and it seems that it's a 4-hour job for a mechanic, so that translates to at least double that for me and a much, much higher chance of messing up my car.
£200 for peace of mind :)
